voice inversion
INDY72
Indianapolis, IN
Just to let you know that technically descrambling those comms is illegal.. this has been your PSA lol now that youve had the usual warning have fun...... lol
KR4BD
Lexington, KY
Years ago, you could easily buy black boxes for voice inversion scrambling for about $20. I still have one connected to an old Regency 10-channel xtal scanner. I was living in Ohio at the time (1970's), near Vandalia (N. of Dayton). Their PD was on 155.625 at the time. If a unit or dispatcher said "signal 54", you knew they were about to scramble. In all honesty, most of their traffic was "in the clear". Most of the scrambled stuff was a riot to listen to.... Often, it was inappropriate communications like the dispatcher asking a unit to pick up two cheeseburgers at MacDonalds for her.... Or that she would be "away from the radio" for a few minutes...
INDY72
Indianapolis, IN
Also if you have the cash there are two scanners on ebay right now that already have the software built in for descrambling inversion.. one of which is an export only not for US model but on ebay.. everything goes eh?
INDY72
Indianapolis, IN
In Concordia Parish LA.. Go up...Pike County MS go 10-S.....On the old radios for MBN Go blue... but now MBN has true encryption on thier radios.
scanfan03
Houston, Texas
Yup I know, but it's my own company's radios.
Thunderbolt
Global Database Administrator
Ann Arbor, Michigan
Here in Michigan, it varied with each agency and what their policy was on using them. However, those that had them did make good use of this technology.
EMTS Ambulance: 10-90
Escanaba City Police: "Go to Code"
EMU Police: Code 7
Monroe County Sheriff: 10-90
Pontiac City Police: "Ch-3"
Ypsilanti City Police: Code 7
73's
Ron
scannerfreak
Well Known Member
Indiana
cellblock776
St Gabriel, Louisiana
Hammond, Louisiana Police Department used to use Speech Inversion on it's detective channel from time to time many years ago. I used to monitor their channels quite a bit since my father was a Detective with them. Not sure if they still use it.
A couple of months back I posted about hearing Ascension Parish Sheriff's Office testing Speech Inversion on a talkgroup on it's Motorola TRS.
n8gni
Michigan
Speech Inversion
I used SSB on most I heard. Some USB and some LSB.
Of course you would need a radio that had sideband, I used an AOR 3000a.
I now have an Alinco DJ-X2000e that has a descrambler built in, I've never tried it cause I never hear any Inversion anymore!
Voyager
scanner_freak said:
Yes, most of them do require discriminator taps.
That's odd. You shouldn't need a discriminator tap since most of them are only dealing with the audio portion of the spectrum (300-3000 Hz), and invert around 2700-3300 Hz or so. A discriminator tap should not be necessary.
Joe M.
