VoIP and 911 Calling
SLWilson
Ohio
VoIP is going to be a NIGHTMARE for 911 Centers.
Granted, if used properly, it will be a great thing.
BUT, for those wanting to cause problems or reak havoc for any 911 Operator, in won't be good at all!!!
Who is going to keep up the caller's data? Who is going to VALIDATE whatever info caller's provide to their VoIP provider? It can be used "anywhere" the user can get an Internet connection so HOW will you locate a VoIP caller who doesn't know where they are? Who will PAY foe the technology required for local 911 Centers to RECEIVE these calls? If I have my VoIP registered in Columbus, OH but drive to Cincinnati, will the call go to Columbus or Cincinnati if I dial 911?
The craziness just keeps compounding!!!!!
Steve/KB8FAR :(
seamusg
Grand Blanc, MI
Steve/KB8FAR :(
It is up to the VIOP provider to supply the correct info. If they use the 911 network then they must supply the correct info to the 911 database for the call to be routed correctly. The biggest problem is that the VIOP providers don't want to pay for access to the 911 network, and just route the calls to the non emerengcy numbers for the local PD or FD. When I worked on the E911 DB/ALI system it was a two part deal to get the info. First the PSAP got the phone call with ALI info then it sent the info to the E911ALI system which sent the persons name and address. I've been retired for 6 years so I'm not sure if the system is the same.
SLWilson
Ohio
That's the problem
seamusg said:
It is up to the VIOP provider to supply the correct info....
That's the WHOLE problem in a nutshell! We get calls every day on VARIOUS phone lines. We even get calls on our office ADMIN lines that might NOT be answered after hours. VoIP aren't the only vendors doing that either. Cingular, W.Va. Wireless and so on. We CAN'T get ANYONE at either place to fix it either. I suppose they'll just have to get SUED for not processing their customers calls correctly!!!! Steve/Gallia :( :( :(
matthewtomek
Live Audio Admin
Memphis, TN
We have not had a big problem with VOIP yet. Time Warner Cable offers digital phone service here in Memphis. I have noticed an increased number of VOIP 911 calls, but ALI information seems to be correct so far.
