RickS31
Rick, I'm using the "C" adaptaplug, and it's oriented correctly. Haven't checked the voltage, but I'll take a look at it when I get home.
Sounds like you have the right dog. Once you check it with your voltmeter at 9V with a positive tip you've pretty much eliminated it as the problem. Then *shudder* you may have a bad 106. If that's the case I hope you're still under warranty.
Be a shame to keep buying adapters and not having any success. May be worthwhile taking the radio to your Shack and let them try different adapters and tips. Both the B & C tips fit in the radio. Just as an aside, you do know that you have to power the radio off and then back on after inserting the adapter when the radio is already on, correct?
