VSP Signal 4
mrdelia
Pottstown, PA
Does anyone know what a "Signal 4" is. Heard dispatch ask trooper if he was signal 4 and sent him backup..
It's not listed in the collaboration page..
Just wondering. Thanks
PorterHouse
Hampton, Virginia
I have listing that says Signal 4 is "Serving Papers". For that task, they might send a backup, depending upon the subject and nature of the "paper".
Hopefully this copy will appear readable and understandable on the thread...
VIRGINA STATEWIDE SIGNALS:
1 Transport Prisoner 33 Attempt to Locate
2 Meal 34 Meet or Assist Officer
3 Flat Tire 35 Citizen Holding Prisoner
4 Serving Papers 36 Investigate
5 Using Telephone 37 Armed Robbery/Holdup
6 Shop Repair Or Service 38 Breaking And Entering
7 Radio Repair 39 Bank Robbery
8 Meet Another Unit 40 Homicide/Murder
9 Coffee Break 41 Suicide
10 Vehicle Breakdown 42 Gambling
11 Personal Reason 43 Rape
12 Traffic Court 44 Malicious Wounding
13 Circuit Court 45 Child Molesting
14 Juvenile Court 46 Person Screaming For Help
15 Turn In Report 47 Shoplifting
16 Radar 48 Send Sergeant/Lieutenant
17 Checking Detail 49 Vandalism
18 At Office Or Station 50 Theft/Larceny
19 Follow Up Investigation 51 Trouble At Station
20 Building Check 52 Subject Likely To Flee
21 (blank) 60 Overdose
22 (blank) 61 Cardiac
23 Open Door 62 Head (injury)
24 DOA 63 Eye - Ear - Nose
25 Close Door 64 (blank)
26 Notify Magistrate 65 Abdomen
27 Officer Needs Help--GO! 66 Orthopedic
28 Female In Car (mileage) 67 Burn
29 Airport Alert 68 (blank)
30 Notify Hospital 69 Transport
31 Any Traffic For _____? Blue Life Or Death
32 Plane Crash
PorterHouse
Hampton, Virginia
OK ... it didn't post too well. What there should be is two columns: number and its meaning, number and its meaning. The last item on the right-hand column is "Blue" and not a number (as in "Code Blue"). With the push for law enforcement front-line personnel to be either EMT or Medical First Responder certified, medical terms are included in the signals.
mrdelia
Pottstown, PA
Wanted Subject
I heard later that Signal 4 was confirmed and the warrent was being sent to the jail. The trooper took the subject into custody...
I guess this could be the same as serving papers...
Thanks for the help. By the way the list was understandable.
richrowl
Chesterfield Co Virginia
Signal-4 and plain english
Since the switch to plain english and no 10-codes, 10-4 is the exception, this is perhaps
the Signal-4 in question.
Signal 4 – Confidential/critical information to be relayed. This will be used
instead of 10-16/10-48 to indicate that a possible hit as been received. It can
also be used by the dispatcher to alert the unit that information needs to be
relayed to them that should not be heard by the subject. The unit should respond
with the current location and indicate wheather or not the dispatcher can go ahead
with the information. If the hit information includes a response from NCIC that
indicates one of the terrorist codes – the dispatchers will still use those codes
prior to transmitting the information*:
MOTORHEAD3902
outskirts of tar bay
32 Plane Crash
I can pretty much say that those signals aren't used by VSP. Though, I gotta ask where did that list come from? It's pretty detailed :)
Whenever a unit uses their MDT to check a violator for driver's licensure, the system automatically checks for wanted status. Sometimes, a "like match" will pop up, based on the Soundex system/method (which see). In these instances, the dispatcher is alerted that a unit has a possible wanted hit, and the CAD system provides the dispatcher with all the information (unit checking, name of possible wanted person, etc) so that they may verify the information and secure additional resources for the unit in the field. This explains the dispatchers inquiring "out of the blue" on all these "possible Signal 4" people. Just an officer safety procedure thing.
ETA: Richrowl has the correct definition.
Enjoy the leftover turkey, everyone!!
B A
I listen to the Troopers alot.. Signal 4 sounds like the person is wanted. A few times I have heard the Dispatcher or the Trooper say it is a false hit. Which sounds like the person he has stopped is not wanted but the NCIC has info that is close to the info given.
skannerboy
skannerboy
I have a Radio Shack scanner and use to be able to pick up the VSP. Now I can't even get the county police or the fire department. I even tried hooking up an outside antenna and I get nothing.
Can anyone tell me what kind of scanner I should look into getting? I heard that VSP went to some kind of STARS thing. I was looking at the Scanner Master site and they have triple trunking and digital triple trunking and trunk tracking and all kinds of stuff that I have no clue as to the meaning.
If someone could please recommend a scanner that would work for the VSP mainly and then maybe the county which I heard went digital I would be most appreciative.
Thanks so much for your help!
fmon
Silent Key Jan. 14, 2012
Eclipse, Virginia
GRE scanners are best buys at Scanner Master. PSR-500 (handheld) at 400 or PSR-600 (base/mobile) at 430. Either will track STARS and other digital systems very well. Uniden 396XT (handheld) or 996XT (base/mobile) will also track systems very well.
Radio Shack has the GRE models as Pro-106 (handheld) or Pro-197 (base/Mobile).
I own the two GRE's plus a pair of Pro-197's, all work well on all digital systems I've monitored.
3902... Hope your post means good? Not sure what it meant. Also I traveled to Orange Va last week for a class at the VDFP Division 2. I programmed all the conventional channels and here is what I heard.
Richmond 159.000 ** heard NO traffic on 158.985
Culpeper I heard traffic on both channels
Fairfax I heard traffic on both channels
Appomattox I heard traffic on only one channel
Chesapeake I always hear traffic on both channels.
I have been in Boston the past five days, and will be back in Virginia later this afternoon.
Many 10-42's
MOTORHEAD3902
Yessirrr, your explanation was spot-on (my band's bass player sez that alot...it must mean good things).
And, I dont hear conv ch2 anymore, either. I need to ask my friendly neighbourhood radio tech about that.
Cheers and such
B A
