VST plugin, Filter Beeps. SDR with EDACS96
Hanmer,Ontario,CA
I run two instances of SDR# with Unitrunker and DSD. My EDAC system is very busy and runs on 15 freq.
Edacs runs anolog and Provoice Tg's.
My problem is that when the PV calls come out EDAC spits out the beeps during the call.
Zippyshare.com - DSDPlus-Raw-Input_Best Sample.lost right in the middle.wav
sample.
Dumpt - Image Host
Then I lose decode with DSD getting half of the call.
One had mentioned that it might be possible to filter these tones out 4800 Hz tone mixed with a subharmonic, 534 Hz tone. Using some sort of VST plugin?
So it would look like this
SDR1->VAC1->Unitrunker->SDR2->VBcable->filter**->DSD
Hanmer,Ontario,CA
My problem was a low sampling rate, I thought a low sample rate would zero in on my target freq., making it better. When actually made it worse. It lets in to much interference. Not sure why.
