VSWR Calculation
evfd1625
Indiana
Wirelessly posted (Mozilla/5.0 (Linux; U; Android 4.0.4; en-us; DROID RAZR Build/6.7.2-180_DHD-16_M4-31) AppleWebKit/534.30 (KHTML, like Gecko) Version/4.0 Mobile Safari/534.30)
Can someone refresh my memory on calculating VSWR from forward and reflected power? Just helped someone with some transmitter problems and had 15w reflected, 30w forward out of a 50w transmitter. Fixed the antenna and got 48ish Watts forward and 1 reflected.
cabletech
Puget Sound
What type of radio & frrequency? What type of meter? Normally, you can connect the radio get your readings, reverse the connections and see if you get the same readings.
If yu do then your meter is reading fairly correct.
evfd1625
Indiana
It was a Kenwood, 2 meter, and a Bird watt meter.
nd5y
Wichita Falls, TX
majoco
Stirrer
New Zealand
SWR = (1 + (√reflected power/forward power)) / (1 - (√reflected power/forward power))
according to my ARRL handbook 1982.
The ITT Ref Data book gives the Wiki formula - far too complicated for this guy!
