VW Jetta GLI Install
bgav
Central MA
RAM Mount for BCD436HP in center console mug holder, clips in using belt clip. Proclip USA mount in background for PSR-800 running Spectrum Sweeper. Larsen Tri-Band on trunk using NMO trunk lip mount. Garmin GPS 18x visible on center console.
I can quickly change configuration for HP-2 (pics to follow).
Edit: Please move to the proper subforum. Thanks.
K9JLR
McDonough County, IL
What model year is your Jetta? I have a 2016 1.4 T S-series, and haven't been able to find a pro clip that specifically works for the model years beyond 2015.
Sent from my Pixel XL using Tapatalk
lou9155
shamong nj
love the ram mount.thats my exact setup too...it holds my pro 651 and bcd436 perfect although i removed the belt clip on the 436 and it sits much better
bgav
Central MA
Thanks for the tip. I was leery of it but the scanner seems to fit snug in the holder without the clip.
Sent from my iPhone using Tapatalk Pro
K7MFC
WRAA720
Phx, AZ
Very nice. Always a fan of the cup holder Ram mounts. Very versatile and looks good too! Got any antenna pics?!
bgav
Central MA
What is the model of the RAM mount you have?
RAM-HOL-BC1 belt clip holder
RAM short double composite socket arm
Ram Mount 2.43 x 1.31 Inches Composite Diamond Base with 1-Inch Ball
RAM RAP-B-299-4U RAP-B-299-4U cup holder base
andelliotsaid
Does the belt clip holder mount directly to the cup holder base? Or do you need the ball / arm to mount it? I like this setup for my 2014 jetta
