cwb212001
I have a 2100 that is programmed as a two tone page decoder. Works great... except when I want to run it on a small regulated power supply (2.5A). Here's the thing. I can run it on a 12A power supply with a tx frequency programmed into it and it will decode, open up and reset just fine. If I put it on the 2.5A supply it will power cycle once the 2nd tone starts to come across. After a bit I figured out it was because it was trying to transmit upon decoding. So I deleted the tx frequency making it receive only. After that it... either power supply it will not decode, beep, open up, ect... the '1' on the display just flashes and I have to power cycle the radio to get back to 'normal'. I've done a lot of programming on Kenwood, Motorola & Icom but can't figure this out. I've seen the transpond upon decode feature in other radios but can't figure out if this radio has it or where to turn it off in the program. My service monitor has verified that the radio is transmitting when it decodes. Any ideas? Any help would be greatly appreciated!
