vx-3000L software
wa2chj
Charlotte, NC Metro
The only software I see for the VX-3000 - of any flavor - is in the legacy section of the Vertex Standard site, so it must be a fairly old radio. The software is called "Programming Software VX-3000".
ffemt6488
troy mo
software
I've got one of the versions called ce19 but I've also read that the version 4.04 is correct but can't confirm it
wa2chj
Charlotte, NC Metro
Vertex Standard's oldest software on the matrix is CE20 for the VX-2000. Searching on the web, I found the same thing you did that CE19 ver 4.04 is the most current. Have you tried it?
wa2chj
Charlotte, NC Metro
Oh, then I see your dilemma! I have NO experience with the old Vertex mobile software, but a lot of experience with programming the HTs starting with the VX-160/180 series and newer. None of those have selectable number of channels.
I'll try to download the software and see if I can see anything that will help you out.
wa2chj
Charlotte, NC Metro
I guess I'm going to be no help at all. I downloaded the software and unzipped it, but I get all kinds of warnings from Windows 8 that the software is incompatible. It won't install, so it won't run.
Hope someone else has the answer for you.
ffemt6488
troy mo
It's dos based from what I can tell I'm using win 98 I've also read that if you read the code plug it will switch to whatever format it is
ffemt6488
troy mo
ok fixed in order to use it on any other band,or channel allocations you must first read the radio in witch you want to program and then save it for future use
