Hi all, I have a vx-3000V, ce-19D software running fine. I have a programming issue. When programming the radio for 1200 baud packet, etc, you select fsk 12/24 with spacebar for 1200 baud. After resetting the radio , then testing the radio , upon transmitt the radio puts out a continueous tone, for as long as you key up the transmitter. I made sure tone burst is off, and no other items selected on that command line for that frequency. I also looked in Common files, etc, misc, for others settings and not sure if really anything there applies to packet data use. If i remove the 1200 baud setting the radio works just fine for fm use, with no tone heard, just clean audio. I was hoping to resolve this issue for use with packet, and
tnc-x.
I currently have a setup running with the tnc-x using just 4 wires for audio in/out, ptt, ground on another radio,newer icom208h and tnc works fine with Rms Express for e-mail. Any thoughts on the programming issue for the vx-3000v ?
Bruce
tnc-x.
Bruce
