VX 4000 narrowband compander.
ozzie
mn.
I am programming a VX4000 mobile and am having an issue with enabling the compander for channels that I have selected as narrowband. I change from W>N and then attempt to change from --- in the com column to a "v" but the software will not allow it to happen. I am able to make it work correctly when I swithch to my VX5500 radio.
mancow
N.E. Kansas
I ran into this same problem.
The help files are worthless. From what I could tell they want you to assign it to a button first for some reason. I tried doing that and the ability to toggle the (v) in the software was then enabled. Even though it showed up it still acted strangely. I couldn't tell a bit of difference at all with the compander on or off. I'm not sure if I had it set up correctly or not because the whole thing was confusing and strange. We ended up giving up on it and ran without it. Our problem now is the VX4000V mobiles are very quiet compared to the Motorola HT and CDMs even after I ramped up the VX's modulation.
