VX-4200 use with repeater
OmFromAbroad
Hallo ^_^
I'd want to store the follow details in my radio,but I can't found the instruction to insert it.
frq : 145,600Mhz
shift : -0,600Khz
tone : 110,9
Best regards and I hope to receive and answer ^_^
62Truck
Ordinary Subscriber
Uranus
Well you would type 145.600 into the RX slot and you would program 145.000 into the tx slot and the tone would type and select ctcss and select 110.9 on the enc part... Hope this helps
OmFromAbroad
Many thanks for your answer,I hope this can help me,but I can't found the selection button where I can use the CTCSS tone.
The radio is VX-4204 E (VHF 134-174 MHz) and the SW is CE-59.
Best regards ^_^
radio259
Pittsburgh PA
Vx4200
Highlite the decode block. press space bar, then hit enter for selecting standard tones.
For DCS, hit space bar twice, then DCs selections will show up and select from there. if you do the decode column, the encode will copy.
Hope memory on this is right.
good radio also.
OmFromAbroad
Many thanks for your support and now I can insert the right tone.
But where I can print a manual for software CE-59?
Last question,I've installed the FVP-25 Encryption Unit (Band Inversion Type) and DTMF Paging.
I've only selected the option mode,but I want to know how configurate it. In the ANI option I've choose the code,so my conversation is crypted or not?
Best regards ^_^
