VX-4207 / VX-4600 Out of Band???
NC4AB
Wallburg, NC
I realize these are 20-year-old radios but came across some of these radios that are on the "D" band (450-520 MHz) and would like to put them on 440 amateur frequencies.
I found several 10+ year old threads describing how to get them out of band but the steps described didn't work on the newer software versions.
Any tips / suggestions / pointers would be appreciated.
NC4AB
radiotweester
Oregon
If that was the 4200 info I posted??? It works on CE59 V5.04
Get Windows Enabler and open it and click on the folder icon so it says On.
Unwrite protect/Read-Only the default ud file.
Open CE-59 and open the default ud file.
Go to Common then hardware and change the 450 to 440 then Save.
Read your 4200 and you should be good to enter ham 440.
I've not gone below 440 because the RF final is rated 440-520MHz (Mitsubishi RA45H4452M)
Let me know if this does or doesn't work for you.
The 4600 is the same instruction wise. I don't have the final info handy.
73s
NC4AB
Wallburg, NC
Radiotweester -
Your instructions worked perfectly for both radios!!!
If you ever get to North Carolina I owe you several rounds of your favorite beverage!!!
Andy
radiotweester
Oregon
(y) Glad it worked for you. Good to have a report on the 4600. It MIGHT be possible to go lower, but VCO lock and TX RF, eh...
You might want to check RX sensitivity. I was looking through old posts and saw the one about VCO unlock around 442.
My primary 4200 is an A not a D. If you program and the display is flashing afterwards on a channel, the VCO isn't locked on that ch/freq and you'll need to use the Basic Alignment in the CE-59 to get this back to lock. I think dropping the 451 value should do it. I didn't mess with it as I had 446 and a couple 448/R.
!!! - A warning for others: The upper band 480-520 will be impacted by messing with the VCO setting. Filtering may also impact Ham RX.
Danny37
New York City
How much of impact would dropping it to 440 make on the upper T-Band? I was able to get a vx-4600 down to 440 but im worried about the performance in the 480-490mhz range (RX Only)
Would it help to drop 520mhz to 510mhz? ie. 440-510?
radiotweester
Oregon
Unless you're retuning/messing with the VCO dropping the upper isn't going to do anything. You can try 440, but you may have a significant TX power drop. The Mitsubishi power modules aren't as wide open as the Motorola. I'd suggest programming 440-449 with 0.5MHz steps and measure power. RX is more forgiving, but if you have the ability/access to a service monitor I would check it. If you get a flashing display your VCO is unlocked and you'll need to go higher in the 440 freq.
Danny37
New York City
Apologies, I meant to say the 440 band will be rx only, no TX. Same goes for the 470/480mhz band. Should I be worried of needing an alignment? Radio is used primarily for gmrs repeaters and volly ems in the 460 range.
radiotweester
Oregon
Both the A and D versions are great for 450-470 and then their individual ranges kick in. If you're using it to TX for Commercial and GMRS, don't mess with anything alignment wise!
The reception down to 440 might not work. Program it and see what you get.
Each radio is a bit different. I got one version A (400-470) to drop down to 380 RX before the VCO unlocked. I tried a second and I couldn't get below 390.
