VX-4207 Won't Power On
b18c_ej8
Central New York
I have a VX-4207 that draws current for a split second when it attempts to power on, then ceases to function at all.
Motorola/VX doesn't support this thing anymore, so no Depot repair available.
Anyone ever run into this before?
radiotweester
Oregon
Sounds like Ignition Sense might be enabled. That's pin 8 and in the software Port 1 and it can be turned off as Ignition under Common -> DSUB-15. If I remember correctly the Accessory Ports 1-6 are pins 8-13. Pin 14 is +5V out COR on CSQ/PL/DPL
If you have the software CE59 (still free) and cable you might try reading the radio (read button in software and the turn radio on at button) and see if it will kick on that way. I don't think it will, but maybe. The service manual is all over if you do a search.
