VX-8DR - New to Ham Radio - No response when trying to transmit
lahori
Hi,
I am new to Ham Radio, just passed my technician and general exams.
Bought VX-8DR Yaesu.
Trying to hit repeater in GeorgeTown TX, 146.640, but no luck. I can hear people on 146.640, but when try to transmit, seems like no body is hearing me.
I have set A-band to 146.640 and when hit the HM/RV it shows 146.040
Also the SQLTone is set to Tone, Split is ON. Offset is 600khs. Shows -RPT
Appreciate any help.
Best Regards
ResQguy
Meh
Did you set the repeater's CTCSS tone to 162.2 also? Page 35 of the manual explains that step.
jaspence
Michigan
VX-8DR
If you are programming from the keypad, think about getting the software. The is a very complex radio and as hard to program as some of the Chinese HTs.
N8IAA
Fortunately, GA
Hi,
Best Regards
Provided you are using the antenna supplied with the radio, the high power mode, and the proper transmit tone for the repeater, it will truly depend on the distance to the tower.
The greater the distance and terrain (trees, buildings, etc.) all have to be taken into consideration. You may need a gain antenna to make sure you are able to access the repeater.
Welcome to the amateur radio community.
Larry
pinballwiz86
Missouri
Hi,
Best Regards
It looks to me like you programmed everything correctly. Good job. The problem is that the repeater is an alligator. What's an alligator you ask?
An alligator repeater is one that has a big mouth (you can hear it) but it can't hear you.
Try to get to higher ground and try again. Buy a better antenna to replace your rubber ducky. Or hook it up to a mag mount antenna for more gain. If that all fails, look online for a closer repeater.
But really, you should look into getting a 50 watt, 2 meter radio, and an antenna up on your roof. Then, you should have no problems. It's tough trying to get out with just a 5 watt HT..even a really nice one. lol.
WB4CS
Northern Alabama
Outdoor antenna. Problem solved.
Outdoor antenna + mobile radio with 50W of transmit power = Even better solution.
Welcome to ham radio and congrats on passing your tests! Now the real fun and learning begins. A handheld radio is great to carry around, but hardly something that will allow you to communicate more than a few miles.
If a base antenna or radio are out of your budget right now, try getting a different rubber-duck antenna. Maybe one with more gain. Most stock antennas are nothing more than radiating dummy loads. That might help out a little, but you'll still probably need to find a high spot outside of your house to really get any kind of transmit distance.
