VX-900 Help
usfsengine
Alturas, CA
Hello I have a VX-900 with full keypad. I have a cable and software CE39 for programming. The problem I have is I have entered the frequencies, but any time I change a function for the buttons like the top orange button, the top side and the bottom 2. It dosnt download to the radio? I have tried switching them to different combos and it dosnt work. Do I need a new updated software? Do I need to reset the radio? Maybe whoever can help me can send me a private message, Im sure there will be alot of emailing back and fourth. Any help would greatly be appreciated. Thank You
W2NJS
Washington DC
I used to have two VX900s and I still have the CE39 on this computer so I went there and ran through the switch setting functions to refresh my memory of how it works. Under the common pull down you get to the key function box and you assign the functions you want. You click the OK button at the bottom of the box and that should do the changes. If it doesn't then you've got a problem which could be with the program not being up to date or an internal radio problem.
