Attempting to program VHF P25 non-encrypted non-simulcast non-trunked channel into my VX-P829 using Talon software. Under the P25 RX settings the mode is set to "D", NAC is set properly; SQL set to "N", MONI set to "Disable". In the P25 Function, set for a TGID of "1". Radio will not pass audio, though I can see that a signal is being received on the screen and because the green light flashes. And I can receive the traffic just fine on my Unication G5. What am I not setting correctly? Is it perhaps the P25 RX "MONI" mode needs set to either "Code SQL" or "Noise SQL" instead of being disabled?
Also, can you use the NAC wildcard (3966) and TGID (65535) in these radios if you don't know the correct NAC/TGID? I my case, I do have the correct NAC and TGID's for the channel I'm trying to monitor, however.
Thank you.
Thank you.
