SirJ
Intelligence Everywhere!
Los Angeles/Ventura County
I forgot the password to my radio and cannot read or write to it or use FPP.
Tried: -manu and Developer Only.
But get Model Mismatched! When I read or write to radio.
Ant9270
The Green Weenie
You can try pushing in a "new" codeplug, but it may not work. Give it a try and see what happens.
Ant9270
The Green Weenie
Looks like that worked. Thanks! It does says encryption error when writing to radio but that's ok
You may have to go under the encryption tab and rekey whatever you had loaded.
SirJ
Do you know how to change the RX light on the top right of the radio?
If you into test mode you can see all the colors but no setting to change tx and rx led
Ant9270
The Green Weenie
Can't be changed, the reason for the multicolor lights is because it can be changed if the radio is capable of two tone alerts. Unfortunately, as you know with the talon CPS, It's not possible.
SirJ
Ah, ha.
Ok what about with the vxp929 with two tone enabled. Where are the settings in cps to change the LEDs?
Ant9270
The Green Weenie
Ah, ha.
I dont have my work laptop in front of me right now to check, but it should be in the upper tab bar, under signalling. You should be able to set the LED light to the color of your choice when it detects the correct tones.
