VX2200 Reboots when programming
patmeaden
Poughkeepsie, NY
I got a VX2200 from a local school district a year or two ago and just got around to programming it. whenever the radio is on and the programming cable is connected to both the radio, the radio reboots reboots. I'm using an old PC power supply at 12v, and the programming cable that I got with it (which I'm told was used to program then when the school got them).
MBill
I would check that you are getting enough amps out of the PC power supply. You need at least 15 amps for a VHF model and 10 amps
for a UHF model for 20 watts for transmitting. Don't recall how much amps for receive\programming, ( I think around 3 to 5 to amps) but your power supply should be able to put out at least 10 amps to be on the safe side. Also the radio is rated for a 13.8 volts supply.
patmeaden
Poughkeepsie, NY
its currently running on 12v at 18.5A, but ill see about getting 13.8V
n3obl
Ø
PA
Some aftermarket cables don't work well with the vertex and cause the radio to continuous reboot. Will probably need an OEM cable.
radiotweester
Oregon
I agree with the potential cable issue. Is the cable serial or USB? Make sure you read, save, edit, rename and save and write back. Also, plug in the cable and power the radio up only when the CE82 tells you to. I'm not sure how or if the Motorola
a417
The power supply is pushing 18.5A when you program it, or its capable of pushing 18.5a on the 12v rail?
I have made many a bench supply out of old ATX power supplies, and few and far between will push the 12v rail much over 12.2v w/o some resistance...with most hovering at 11.9v. They are not terribly great for radios, and usually crap when you start to TX on them. The RF wreaks havoc on them if you don't have a great radio antenna/grounding setup.
The 13.8v usually referenced comes from a standard alternator charging voltage of 13.8v to 14.2v in a running infernal combustion engine, and radios will usually run just fine on a resting lead acid battery voltage of 12.4v-ish, so you might not find one that is designed to put out 13.8v for a bench supply.
I join the "question the cable" club.
