VXR-1000V uses for ham
WX5812
Fort Worth
I have several VXR-1000V VHF crossband repeaters. Ive seen where the UHF version can be hex edited into the 70cm ham band, but I cant find anything on hex editing the VHF model......If this thing will work like I think it will, It can be used as an allstar node,repeater low power link radio....Is there anyone who has repurposed these for ham use? If so what did you do?
AA4TX
IONAFLXARS0
I have used them for their intended application (vehicle extender) in Amateur service, both VHF and UHF. They work very well with the Kenwood TKx80 series mobile radios!
WX5812
Fort Worth
Thanks!!
If I would of waited I would of answered the vhf coverage question. I have one receiving on 2 meters, but If I put +5 to the cor pin I cant get it to TX
900mhz
its possible that the COR pin is active low...depends on how its programmed. In that case, ground that pin.
WX5812
Fort Worth
I have it all up and running. All good except for a hum in the audio....Going to check power supply and see if I cant get that to go away.
WX5812
Fort Worth
Power supply was the issue with the hum. Got it all working... I have 2 of them hooked up to a Arcom RC210 temporarily. They seem to be working very well. I will try and use it at home and connect a remote base (TM-V7A) and an allstar node to it to play around with.
