vxr-7000 dealer mode
ke8ywa
I have a Vertex VXR-7000 I'm trying to program on ham band. I have the windows version 1.08 of the euro ce27 software and have been unsuccessful at changing the target path with the -d or /m to allow programming on ham bands. I have a bluemaxers49 cable, and can get it to read and write, but cannot get it to program on ham band, because i cannot get the dealer software to work. Can anyone help point me in the right direction?
AA4TX
IONAFLXARS0
I have a working shortcut that that the "Target" as:
"C:\Vertex Standard\CE27 for Windows\CE27Win.exe" -p
ke8ywa
That's what I get with-d /m and your shortcut. spaces, no spaces, quotations, doesn't matter. I haven't been able to find the right combo yet.
AA4TX
IONAFLXARS0
This is all I need to have full edit acccess to the .c27 file:
I am running Windows 11, and CE27 v. 1.08. -p is the only modifier.
No -d /m or anything else.
Of course, the program CE27 has to be located in "c:\Vertex Standard\CE27 for Windows"
AA4TX
IONAFLXARS0
Tried the "-d" argument in place of the -p. Same edit capability, but gives access the the call sign editing as well for CW ID.
ke8ywa
Where did you get your software? Maybe my copy is missing the correct files.
AA4TX
IONAFLXARS0
I bought it from a Vertex Standard dealer directly back in the day when I bought the repeaters Started out with DOS, then Windows. Not much more than the .exe file, and associated help files. the .ini file is created when you first run the exe.
Your error in the screen post indicates that you do not have the CE27 executable in the directory that you are specifying, not an issue with CE27.
