VXR-7000 DSUB Channel Control
iceman977th
Catlettsburg, KY
Out club has a VXR-7000 connected to an Arcom RC-210 controller. I have a macro set up for a power failure that changes the courtesy tone to let us know there has been a power failure, but we’d also like to reduce repeater power automatically to extend our runtime (we lasted about 2 and a half days at full power on two deep cycle batteries.. not bad, but with minimal use.. more batteries and a solar system on the way soon)
Ch 1 and 2 are set up the same, with Ch 2 being low power and Ch 1 being high power. However in Remote mode I know you cannot change the channel from the front panel. Pins 16-19 are channel control. Pulling Pin 19 to Ground would effectively change from Ch 1 to Ch 2 (in theory without needing 16-18 connected as they all stay high) but I do not know if that still works when in remote mode.
Does anyone know if the rear channel pins will work as intended while in Remote mode and this will work? I wanted to ask before I start wiring and programming the controller for it.
Mike
radiotweester
Oregon
The only thing I'm familiar with is the Power dropped to 10W on DC, but I'll look.
CE27 for Windows
Common -> Radio Status -> DC TX Power Low = enabled
edit: It's channel steering only on pins 16-19. If you're running DC only the option above wouldn't work, but you could use a relay drop-out to steer to ch2.
Not a great idea, but you use a relay to switch the low power button on the front panel. I'm not familiar with your controller, but maybe an I/O of DC and momentary latch there?
