VXR-7000 Power Mod?
hardworkn247
Long Island, NY
Sorry to disappoint but this is actually a question to turn power down on the unit. Unit can be dropped to 10W turning unit into dc mode or selecting it through programming. Any one have suggestions on turning unit down between 3-5watts output?
hardworkn247
Long Island, NY
Forgive me but, I do not see where within the forum you can pm another member. I can only assume it is because of my post count and being new.
Sent from my SCH-I535 using Tapatalk
Arizona
hardworkn247
If you click on VSTech screen name you should see a drop down with options on it. However I tried to click on your screen name and the "private message" option is not there. You may have the private message option turned off in your "User CP". If you have it turned off on your end, then PM's shouldn't work for you at all, in or out.
hardworkn247
Long Island, NY
Ok I found the messaging setting and enabled it. Still don't see it but will look around a little more. Not sure if its because I am a new member and still on post probation.
hardworkn247
Long Island, NY
Oh and to correct what I said before. This set up is NOT using a duplexer. This machine has both a transmit and receive antenna. Thanks again and sorry for the confusion.
