VXR7000 Noise
Thinblue
Newport
I am new to the Vertex line. I have two VXR7000 and a VXR5000. I am used to Kenwood TKR and NXR series and I have a problem. The VXR 7000, both of them, puts out noise, with the PL on the frequency it is set for. Not a powerful noise, but powerful enough to keep any radio in the immediate area from scanning.... they lock on to the frequency. Clear as mud?
I recall in the old days, with the Motorola bricks in LE, that they also put out a detectible noise on its set frequency when in monitor.
Is this a Motorola thing that I have to live with? I find I actually like the VXR better than the TKR.... except for this....
radiotweester
Oregon
I THINK this model is in constant TX and the amplifier and PL/DPL is only activated during repeat. It's been a while since I've messed with one, but I remember something similar regarding nearby portables. Try a frequency counter near the TX antenna connector.
ramal121
Lots and lots of watts
Calif Whine Country
If the repeater is able to be programmed as a simplex base station then the idle TX frequency needs to be shifted otherwise it would fubar its own receiver. In the TKR/NXR this is a manual selection in any operation mode. I'm not sure about the VXR7000 but it might be automatic only when the TX and RX is the same. Maybe check the help files.
cmdrwill
So Cali
Exciter VCO stays on. The TX amplifier stages stay off, idle, and are keyed on for Transmit.
