Turbo68
I bought this loop few months ago results for monitoring the hf aero are excellent i got an Elad ASA-16 active antenna splitter can this be used in my shack with the loop...
Regards Lino..
Regards Lino..
My plan is to eventually mount a rotor to turn it remotely, probably using an inexpensive rotor. Anyone doing this?
My W6LVP is now up using a RCA rotor, so far for the most part it receives as well as my 31 foot vertical. For LF and Medium Wave it's better than the vertical'cause you can rotate it. So far am very pleased, but am looking forward to the winter to do some serious evaluation.
Is that a metal or plastic rain gutter behind and above the loop? If its metal you know what my next post will be.
In addition to being as far away from the house, don't put it too close to the vertical. You want to avoid the chance of it interacting with it, mostly on the higher HF frequencies....and also to avoid any incidental RF from the vertical when you transmit (unless you have the T/R switch option...)Mike
