Wake Co NC TRS CC Change
The long standing control channel for site 10 has changed this morning. It is not known if this is a permanent change or temporary. The new control channel is one of the alternates, 853.7875. If you have all the alternates programmed in there shouldn't be a problem. Otherwise you will need to add that to Site 10.
Apparently the WAKE system keeps going down. Hearing County Fire, Raleigh PD and EMS utilizing the backup viper talkgroup for wake county.
kellsdalegend
I noticed can't hear any rpd tonight. Im using ws1080 what should I do to be able to listen
@kellsdalegend they had a number of problems last night and the cc kept changing as well as the system going down. Seems like it is working this morning. Make sure you have all the Alternate CC's programmed in your radio. Current CC is 853.5375 but may change again.
