Wake County P25 switch
ScannerHead44
Mebane, North Carolina
The past couple of days, I'm unable to monitor anything from Wake Co. - PD, Fire, Sheriff. Complete silence. However, I have no problem with VIPER Statewide, which is the only other digital system I have programmed.
(BCD996P2)
I have the same scanner, and while I have no problems hearing Raleigh PD and Cary Fire(I live in western Cary), EMS dispatch is very garbled.
KO4RJX
Benson, NC
Anyone have the ID for either RDU Operations Dispatch and/or RDU ES Dispatch?
PapaWolf83
Southern Wake County
I have a Uniden BCD536HP. Scanning was fine until this week. Seems there are all new Talk Group Ids now. My scanner was originally programmed years ago with a friend helping me. Now, I am trying to fly solo with no luck. I downloaded ProScan to update the Talk Groups but still nothing. First tried changing the Talk Group Ids for WSO but no luck. Any help would be greatly appreciated! Or, point me to a doc that would step me through programming the BCD536HP. Thanks.
Chris0516
Pittsboro, North Carolina
Did you create a new system for Wake County? While the Mot. Smartzone Type II is still being used. They are steadily migrating over to Cary/Wake25: Cary/Wake P25 Trunking System, Cary, North Carolina - Scanner Frequencies
I have both on my BCD325p2. I also have a Registered version of Proscan. The only consistent activity still on the old system, is on the analog part of the system. There are a few digital channels on the 'old' system still in use. But, They will be switched over to the new system.
PapaWolf83
I have both on my BCD325p2. The only consistent activity still on the old system, is on the analog part of the system. There are a few digital channels on the 'old' system still in use. But, They will be switched over to the new system.
Thanks for the reply! No, I did not create a new system for Wake County. I used ProScan to read the data from the scanner. I changed the VIPER category from Motorola to P25 Trunk after reading thru the conversations. Then, scrolled down and changed the Talk Group Ids under WC Sheriff Dept. to what were posted. Wrote this back to the scanner and started Id Scanning. But, nothing.
Chris0516
Where Wake County is concerned. VIPER, Apart from the Sheriff's Office, is a backup.
PapaWolf83
Specifically, I have 2 Systems that are scanned: VIPER and Town Of Cary. VIPER was defined as Motorola. I changed this to P25 Trunk. Are you saying I need to create a new System and name it Wake County. Then, define it as P25 Trunk. Then, add Site Names and Department Names to the new System based on the new Talk Group Ids? I see Site Names and Department Names under VIPER.
Again, I have had the scanner since 2014 and a friend helped me get the scanner working back then but am basically new to programming it like you gurus can. Thanks for your patience!
RDU OPS DISP 47387
RDU OPS 2 47388
RDU A TO F 47381 TO 47386
RDU LE DISP 47390
UNKNOWN RDU 47380, 47389, 47391 TO 47395, 47499 (Please post here if you figure these out)
Radio IDs for RDU are in the 1849000 to 1849999 range.
yes you need to reprogram the wake system with new control channels, new tgs and as a P25 system.
Chris0516
VIPER has been P25 for years. It is up to the individual counties. As to whether will be Primary, or not.
Wake County was Motorola Smartzone Type II for some time. While, The Town of Cary: Cary/Wake P25 Trunking System, Cary, North Carolina - Scanner Frequencies. Was Motorola Type II Smartnet. So, P25 is an upgrade for both.
shoegazer
This is probably a MP and not a YP...
But I had my Win500 program connect to the RR database today (10-30-21) to grab a fresh update. Changing nothing in the settings (other than changing the default target list from 'unassigned' to 1); I'm now getting the dreaded 'nothing enabled' when my Pro-106 reboots and begins scanning. Using a saved .p500 file from two days ago works correctly. Again... I'm sure it's my user error. But if this rings a bell for any of the powers-that-be; so be it. I'll check the other threads re: 'nothing enabled' for more troubleshooting. Just reporting what I believe to be a change.
I've attached two screenshots showing the change. #29 is from 10-29-21 and #30 is from today (10-30-21).
Carry on.
mosssw1987
Raleigh
I have an SDS 100 that has been working fine until this change. I have to admit I am not very good at programming scanners. I Generally listen to Raleigh police and fire both dispatch and tac and ops. I use the sentinel software to program. Please tell me what I have to have in there now so I can listen, Please help if you can I am lost not having my scanners in the evening. Thank you in advance!
mosssw1987
Raleigh
I have the Unication G5, Uniden sds200, Motorola XTS/APX all are 100% on the new system, however my uniden 996P2 and other scanners are about deaf.
I’m having problems with my phone don’t understand how do I get my SDD 100 on the system? Please help me if you can I would really appreciate it
murrayustud
KI4DCR
raleigh,nc
Create a new system, p25, Wake County and add it. I’d also delete the old system.
Chris0516
This the Cary/Wake25 page on RRDB: Cary/Wake P25 Trunking System, Cary, North Carolina - Scanner Frequencies
The Control Channels are the #'s in RED. The Alternate Control Channels are in BLUE.
mosssw1987
Raleigh
I will give it a try some of this is really foggy for me. After I create groups of 25 system called with Wake county how do I edit To include what I want
KO4RJX
Benson, NC
RDU OPS DISP 47387
RDU OPS 2 47388
RDU LE DISP 47390
Thanks, Ill plug a few into my G5 and see what I can identify
