KA1RBI
... There is no hardware limit other than ROM space that would prevent them.
Well, proper demod in p25 phase II requires a PSK demodulator, not a FSK-type demod as used in dmr, p25-fsk4, ysf, etc. The symbol rate (6k) in phase II is also different from any of the other modes (all of which are 4.8k baud except nxdn48). So unless the AOR unit is already equipped with a PSK demod (unlikely) then it's probably a larger issue than just decoder software.
It is a first cousin to DMR as you are explaining with time slots, but not quite, mostly just the TDMA part. Tier 3 DMR and Phase II P25 would be a better analogy.
dmr and p25 phase II are totally unrelated when it comes to the modulation and demoduation layer - on both uplinks and downlinks...
Max
