Wall Twp/Monmouth County Fireground 5?
ajbrenner
Wall Twp, New Jersey
While listining to an active fire in Wall Twp around 11:00 PM last night I heard the Chief tell everyone to switch their radios to Fireground 5-at least I think thats what was said. Anyway whatever they switched to put a quik end to my scanning activities for the night.
My radio is programed direct from the RR Database. A quick look through both the Wall and Monmouth County frequencies did not turn up any named Fireground 5.
Sorry if this is a noob question but I am after all a noob.
Thanks,
ajb
SigIntel8600
Communications Receiver Nut
Pine Barrens
Thanks,
ajb
I show county fire 5 as 154.265 PL 151.4
Let us know if this works out
ajbrenner
Thanks much. Now I see my mistake though. I had Monmouth County in the scanner but I neglected to install Monmouth County Fire/EMS.
Thanks again and stay tuned for more noob qestions,
ajb
DJ88
Brick Twp., New Jersey
If you look in the database here, the numbers in the Alpha Tag column are the channel numbers. Wall Fire 5 is 154.325 PL 131.8. However, it's simplex (no repeater), so you would have to be near the area where they are transmitting on it to be able to hear them. I live in the extreme northeast section of Brick, near the Brielle border, and was listening to the fire also, and when they switched, I was able to receive some sporadic, broken up transmissions on that frequency.
Channel 1, 154.400 and Channel 3, 155.760 are the only repeater channels. The rest are simplex. Channel 3 is used during the weekday daytime hours by the school buses. I believe it's actually licensed to the Board of Education, but they must have agreed to share it with the FD. 154.400 is listed twice, as Channel 1 and Channel 2. 1 is repeater and 2 is used off of the repeater as simplex. Same thing with 155.760, listed twice, as Channel 3 and Channel 8. 3 is a repeater. 8 is used off the repeater as a simplex channel.
Channel 7 is Monmouth County Fire Channel 7. Most, if not all, Monmouth County fire departments have that channel in their radios so they can used it as a common frequency for fire ground communications when departments from different municipalities respond to an incident. Monmouth County Fire 5 is used primarly by Long Branch FD as their primary fire ground channel, although other departments have access to it.
