Walmart radio freqs
Trainguy1997
Front Royal, Virginia
Well I got a new job working at Walmart pushing carts around. Asked to see if I could bring my own radio(the Moto P1225) in since they only have one radio for 4 guys and they said it was fine as long as I could program them in. Does anyone know the freqs for the first and second channels at the one on 5th Avenue in Hammond? I looked in the FCC database here and they were not listed. Any help is appreciated
73
kd9glw
Wal mart uses murs. However I do not recall if that radio is type accepted for murs. Others will chime in. FWIW some dont care and do whatever but it's a personal choice if your caught and the fcc is around its all on you. Wal mart uses murs. There is a few topics on it with the tones used. I forget the links but if you search wal mart frequencies in the rr search above the forum topics will come and a couple have valid listings of what dpl is used and some use a couple pls. Mostly 154.570 is csq. However they do have it on a dpl tone also but mainly run csq on it in most locations.
wtp
Port Charlotte FL
in case you are waiting for a reply, it is late
most of the stores use 154.57 and/or 154.6
usually no PL, if there is it is anybody's guess.
as you see i am not from your neighborhood.
drayd48
Some Walmart stores still have FCC licenses but now most are using MURS. Some have PLs and some don't.
INDY72
Indianapolis, IN
All Wal Mart and Sams are getting licenses again, and are now mixing Analog and DMR operations. From some of the CSMs and ASM/SM I know, they hope to go all DMR by 2020.
