WANTED -ICOM F4061/2 FIRMWARE
EXCALLIBER
My Icom F4062 has gone brick on me and won`t switch on. Was in middle of updating the programming software when set failed half way through the procedure.
Now nothing happens when I switch radio on so assuming will need the firmware reloaded. Is it a bin job or can anyone help me resolve the problem.
EXCALLIBER
Does it say "clone NG"? Or is it completely dead?
Set is completely dead but I did get the RX/TX led to light up red once after pressing a combination of the buttons. It stayed lit for a while when I switched radio off until I removed the battery which I thought was a bit odd.
EXCALLIBER
Set is completely dead but I did get the RX/TX led to light up in ORANGE just the once after pressing a combination of the buttons. It stayed lit for a while when I switched radio off until I removed the battery which I thought was a bit odd.
EXCALLIBER
Member JEATOCK has posted links to all the firmware versions for the F3061 but can`t get any of the links to work. I`ve been told that reloading the firmware will fix the radio!
