Warren County vs. PSR500 --- SOLVED
GrumpyAeroGuy
Cincinnati, Ohio
Warren County Trunking System, Lebanon, Ohio - Scanner Frequencies
OK, after posting that I have had issues with open squelch, hanging on talk groups that remain silent, etc.,etc., I opened a ticket with GRE and have, with their assistance, found my problem.
It is a rebanded system. For some reason, when I reloaded the system after rebanding, it dod NOT create a custom trunking table.
I deleted the system, RE-downloaded it, and it created one. Only, the problem persisted.
GRE indicated the trunking table should look like:
The Trunking Table created when originally downloading from RR looked like this (accompanied by a dialog box indicating something about the potential of "splinter frequencies"):
0 719 0 851.012500 25.000
0 599 0 851.000000 25.000
which still caused the same problem, although not as bad.
Now, I do NOT know much about this, but this did solve the problem on the WC system.
Now, my questions:
1) When DLing a rebanded system from RR.com, should the trunking table create itself?
2)If not, how do I determine the "right" solution, as indicated in the pic above. again, that solution originated from GRE SUpport, NOT from me.
3) What is that table telling me/the scanner.
Sorry, just trying to broaden my horizons here. Thank you in advance.
radioscan
Radio Sensei
Southern Ohio
Database updated
For some reason we missed setting this system to 'rebanded' after rebanding was completed.
I have corrected this, so it should now download correctly in all programs.
Thanks for bringing this to light!
GrumpyAeroGuy
Cincinnati, Ohio
Wow, OK.
Well, I'd be lying if I said that I even suspected this. Glad this helps in some way. I thought I was missing something, or doing something "strange".
