BCT15X: Was using FreeScan to work w/Uniden BCT15X; then installed SDR and software(s) to play around with that and now can not connect to scanner?
spotter503
I installed a RTL SDR V4 and had to install the driver(s) with it-have been playing around with it with some success but am old school and still like actual hardware. I went to re-connect my Uniden BCT15X via the USB cable and it will no longer connect. Does this likely have something to do with SDR install/drivers?
-Windows 10 still
-SDR is unplugged when trying to access scanner
-Any thoughts/suggestions?
Thanks!
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
Likely the driver for the USB connection is conflicting with what the SDR is using. As mentioned above a different USB port for the SDR will resolve the issue
Mike
spotter503
Enforcer52 & ka2jjz-thank you for the input. I uninstalled and re-installed drivers and software multiple times with no avail; then accidentally pulled the power cable from my PC while switching USB slots and when it finally turned back on, all works again. Thank you for the suggestions.
trimmerj
Pasadena, MD
Found that a power cycle will fix a lot of USB troubles, when a reboot doesn't always work.
