Can someone explain the scrambled messages in Washburn County? Any way to "fix" it? Thanks.
imp64 Member Premium Subscriber Joined Aug 1, 2010 Messages 8 Feb 13, 2017 #1 Can someone explain the scrambled messages in Washburn County? Any way to "fix" it? Thanks.
S ScannerSK Member Joined Mar 6, 2005 Messages 1,248 Location Gilcrest, CO Feb 13, 2017 #2 It appears most communications in your area are not scrambled (encrypted). http://www.radioreference.com/apps/db/?ctid=3117 Wisconsin Interoperable System for Communications (WISCOM) Trunking System, Statewide, Wisconsin - Scanner Frequencies What do you mean by scrambled? Are you referring to garbled conversations which can be partially understood or encrypted communications which cannot be understood at all?
sfd119 Member Joined Jul 18, 2009 Messages 1,743 Feb 13, 2017 #3 Washburn County uses sporadic encryption on Sheriff channel. Some days more than others. You cannot fix this.
imp64 Member Premium Subscriber Joined Aug 1, 2010 Messages 8 Feb 13, 2017 #4 Thank you I suspected that was the case, just wanted to ask. VERY annoying yesterday.
