Washington Co. P25 P2
glockluvr63
Washington, Iowa
I loaded the SARA network simulcast P25 P2 system into my sds200 for Washington Co. Not hearing anything on their system. But I am hearing all the area P25 traffic from surrounding counties. Can anybody shed some light on what is going on??
WillB
Henry County
I've been having the same problem myself. I know for a fact that with the exception of 2 channels the fire side is not encrypted and most of the law stuff is not as well.
tvengr
Well Known Member
Baltimore County, MD
What model scanners are you using?
tvengr
Well Known Member
I have a 996P2 and a 536
Washington County uses a 6 site simulcast system which the 996P2 and 536 can have problems receiving. glockluvr63 should not have that problem with the SDS200. What programming software are you using for the 996P2. If you attach the file for your 996P2 and a hpe favorites list file for the 536, I will check them for problems. The same offer stands for glockluvr63 also.
WillB
Henry County
I used freescan and Sentinel software.
tvengr
Well Known Member
Did you create a favorites list in Sentinel or are you just scanning from the database? You will need to right click on a FreeSCAN 996 file or Sentinel hpe favorites list file and Send to Compressed zipped folder to be able to attach it. Click on Attach files and Open the zipped file.
WillB
Henry County
See if this works
  • Washington County.zip
  • BCD996P2 3-2-2021 all update.zip
tvengr
Well Known Member
There is very little for Washington County on the SARA Network. The patches shown are rarely used. Using Sentinel, I would enter all of the conventional frequencies for Washington County. You can probably get DPS on the ISICS system, but you would have to use a site from an adjacent county. I don't see any Washington County sites. On the 996P2 file, you have so many out of range sites scanning on the ISICS system that you will be lucky to hear much anything. Stay with just the adjacent sites.
WillB
Henry County
The 996 file has most of the ISICS channels locked out/deleted except the surrounding counties. That was just the first file I found.
I'm more interested in hearing the Fire/EMS side of Washington Co.
WillB
Henry County
I just went and deleted the stuff I wasn't listening to. If this 536 isn't going to pick up the stuff I want I might as well sell it.
  • BCD996P2 3-2-2021 all update 2.zip
tvengr
Well Known Member
The Wash Co SARA system doesn't have any talkgroups. On the trunked systems, I would change the Audio Type on all talkgroups to Digital Only. I see that you have the Reg 5 Interop talkgroups on the ISICS system which may be used. On the Washington County County conventional frequencies, change the Mod to NFM. Most of the VHF and UHF frequencies are now required to be narrowband. That should give you a little more gain on those frequencies. Also, turn off digital AGC on the trunked systems. The AGC action can increase garbled audio problems if you have simulcast issues.
WillB
Henry County
I've made those changes and moved my 536 to be hooked up to my outdoor antenna. I was picking up the ISICS stuff fine on the factory antenna after I switched to search ID instead of scan ID.
Any reason this won't work for an antenna? Is going through LMR400 cable with an adapter to go from N to BNC at the scanner.
Sirio Antenna SD2000N 100 MHz-2 GHz Discone Wide Band Antenna https://www.amazon.com/dp/B008899J8...abc_SF3ZFE0ERJBMMP15W7W5?_encoding=UTF8&psc=1
tvengr
Well Known Member
If you are receiving everything you want on ID Search, the talkgroups are not the database or have not been programmed. Make a note of what you hear and compare it to the database. After verifying what a talkgroup is, you can submit that information to the database. If the outdoor antenna does not work, it may be overloading the receiver. Also, it is more likely that by using the factory antenna, you are reducing the number of towers you receive in a site which can improve control channel decoding. That is a classic symptom that you are suffering from simulcast distortion Does the outdoor antenna work on conventional frequencies?
WillB
Henry County
Picks up conventional great.
tvengr
Well Known Member
Sounds like it may very well be a simulcast issue. While connected to the outside antenna, turn on the attenuator and see if reception improves.
