Washington Co SARA
WB0VHB
Mt. Union, Iowa
Noticing several new SARA towers around Washington County. I don't see anything in the database yet. Anyone found any active signals?
WillB
Henry County
I don't believe they are up and testing yet. I'll have to ask a member of a dept up there I know to confirm this though.
WillB
Henry County
I have talked with a friend who works the ambulance up there. He states that the switch will happen sometime in November.
timkilbride
Linn Co Iowa
The yellow pins are the microwave towers. I would suspect the simulcast system will be built on the same towers.
Tim
WillB
Henry County
Today Washington Co is moving to their new dispatch center. Law enforcement will then switch to the new SARA system followed by Fire/EMS.
WillB
Henry County
Looks like fire and EMS have made the switch. I'll find out tonight if I hear the test pages at 5:30
mbender77b
I'm new to scanners for these updated systems. Has anyone had any luck hearing Washington County since the switch to their new system? I just got a Uniden BCD436HP scanner. I've loaded the following but I feel like I may be missing something? Will we be able to hear Law Enforcement at all or are they encrypted so we will never hear them?
05C10 (A)010 (A)Washington Co SimulcastWashington851.2375a851.550c852.600a853.7125a
DEC HEX Mode Alpha TagDescriptionTag
292017211TE92 LAW 1Law 1 Law Dispatch
39290997aT92 EMS DISPATCHEMS Dispatch EMS Dispatch
192814b51T92 PT 2 PT PATCHPoint to Point Patch - 155.370 Interop
192824b52T92 VLAW31 PATCHV-LAW 31 Patch - 155.475 Interop
192834b53T92 VFIRE21 PATCHV-FIRE 21 Patch - 154.280 Interop
192844b54T92 VMED 28 PATCHV-MED 28 Patch - 155.340 Interop
WB0VHB
Mt. Union, Iowa
I monitored them for about 30 minutes a day or two after switching to the new system. Everything at that time was encrypted. I have not tried since.
mbender77b
Probably a dumb question but how did you know it was encrypted at that time? Did you pick something up but it was scrambled or did you ust not pick anything up at all?
WillB
Henry County
I spoke with someone who works EMS up there and states that the Fire/EMS side is not totally encrypted. They do have some channels that are though. They are using the Unication G5 pagers. I did notice on the FCC's website that there are these frequencies listed along with the ones listed above.
806.2375
806.55
807.60
808.7125
Are these for testing?
WB0VHB
Mt. Union, Iowa
All you hear is broken bits and pieces of voice. Nothing distinguishable, annoying to listen to for very long. A valid talk group and radio unit number are generally displayed however.
