Washington county Sheriffs talkgroups IDs’ and channel numbers
tloeks
Hillsboro, OR
I have figured out purity much the id for the trunked system, but when they request to switch to another channel it seems I lose them, specifically channel five (5), do they have the capability to switch off the trunk system to a unspecified frequency, what’s happening? The known channels that I have found are: ch-1 (64048), ch-2 (64016), ch-6 (63888), and ch-7 (63856).
radiotweester
Oregon
The channel 5 they are refering to is probably not SO ch 5 but Cornelius, FG, North Plains or Sherwood.
I'd try Cornelius 59312 first, as they chatter a lot on there about people, places and lunches.
If you look on the trunked as the TGs labled as "Detective" are actually channel 5 or their respective agency.
SO Ch 5 is 63952
tloeks
Hillsboro, OR
Thank you for your suggestions I will try some of the other TGs and see if I can fallow them when they switch channels.
Baker845
anywhere
Any one know what Wash Co. So chs 3,4 are?? Are there other Tgs that WCSO uses? Cornelius TG 59312, is thats also used by Forest Grove,North Plains and Sherwood PDs??
thank you
tloeks
Hillsboro, OR
thank you
try these TGs' for wcso
ch-1 64048
ch-2 64016
ch-3 60208
ch-4 58640
ch-5 59312
ch-6 63888
ch-7 63856
pdxbofh
Oregon
ch-1 64048
ch-2 64016
ch-3 60208
ch-4 58640
ch-5 59312
ch-6 63888
ch-7 63856
Channel 3 is called "service net" and during the evening is used by cities to run records checks on people. (Later in the night it is called "City net" and some cities are dispatched here, see previous post regarding City Net)
Channel 4 is INDIVIDUAL agencies RECORDS channel, so if a BPD units says "going to 4" he is going to BPD RECORDS, but if a WCSO unit says "going to 4" he is going to WCSO Records.
Channel 3 is the SAME FOR ALL AGENCIES
ex:
BPD pack set is programmed:
1) BPD 1
2) BPD 2
3) Serivce Net
4) BPD RECORDS
and a Tigard PD pack set would be prgrammed:
1) S. Cities 1
2) S. Cities 2
3) Service Net
4) TPD Records
Hope that makes sense,
Will
