Washington DC - District of Columbia Channel ID's
motorcoachdoug
Silver Spring, MD
Under Channel ID 3 it should be FDMA, -39.000 12.5 935.01250
Then place channel ID 3 under 4
then channel ID 4 make a new ID as 5 using channel 4 info.
Make sure you know what you are doing so that radio DOES NOT AFFILIATE. you have to set up a moto radio totally different then regular programming to work on that system which you do not want to do since it could end up being a matter of life or death if a public safety user can not call for help or no one hears him because your radio is trying to affiliate to the system.
tsalmrsystemtech
Channel ID 1 FDMA - 45.0 6.25 851.00625
Channel ID 2 FDMA + 30.0 6.25 762.00625
Channel ID 3 FDMA - 39.0 12.5 935.01250
Channel ID 4 TDMA - 45.0 12.5 851.01250
Channel ID 5 TDMA + 30.0 12.5 762.00625
Is this correct on how you wrote this back to me? Thanks
Just curious what the Channel ID 3 is for... DATA
dlwtrunked
yes that is the band plan for Washington DC. I ran Unitrunker on the DC system and that is what showed up.
Keep in mind that band plans like this do not even indicate that a band is actually in use. Many systems have band plans listing bands that are not used by them. Calling them "channel IDs" is a misnomer and it is entirely possible that the 935 MHz band is not used at all althugh Unitrunker will show them as they are in the control channel data anyway.
