Need some help understanding if i'm doing something wrong. I have Channels 1,2,3,4,5 programmed with frequencies. Channels 1 and 3 have the same frequency but different 2 tone codes and channel 2 has 2 tone codes programmed as well. When I set the function switch to position 2 which is programmed for scan and I use channel scan mode it scans all the channels just fine, when I use priority scan it scans fine and goes back to channel 1 as the priority, when I use select call scan it silently scans but will only activate for the 2 tone codes on channel 2 even when I know that the tones were broadcast on channels 1 and 3. What am I missing? I have Channel 1 set to F1 and Channel set to F2 and in programming I have all 5 channels checked on priority and channel scan. HELP
