Water leaking Into vehicle via antenna wire.
trentbob
W3BUX- Bucks County, PA
Now, if you do it right:
Ain’t no mountain high enough
No valley, low enough,
Just call me
No matter how far!
I'm so much into nostalgia, and you are a great contributor towards that, Whether it be radio or anything else! Great stuff on this Saturday night.
.Back to the topic, I'm with most everybody else... who wouldn't be? Especially with an older vehicle. Get your plugs or your disc covers, get your little bottle of touch up factory paint.
Drill the hole.
slowmover
Fort Worth
Drill the hole.
Thx. It ain’t just nostalgia.
There’s already 136-threads arguing antenna fact.
Truth is:
We ain’t machines with TX/RX blips & boops.
We are the music.
How your automobile feels about a mag mount, ye of little faith:
With the NMO radio transceiver vehicle upgrade:
Hearing spoken Etruscan off Iapetus ain’t out of the question.
Nothing is.
No one hereabouts arrived by chance.
G7RUX
I recently noticed water leaking in around/ using my antenna wire as a path into my vehicle. I noticed a wet floor several times after a rain. I have a 2016 ford explorer with a mag mount antenna. I had the cable running out the passenger rear window jam. I a trying to figure out a way to stop the water from traveling down the cable into the vehicle. Has anyone ran into this with some insight. I don’t plan on having the vehicle for more than a few more years.
If you’re intending staying with this setup then you will need to arrange the feeder so it passes through the seal goin upwards. Try to use an area of seal that is underneath the opening since these factors should help to reduce the amount of water that will run through.
i have seen and used bits of smallish feeder with a rubber “wedge” that allows a smooth transition around the feeder and this helps to keep the seal sealing too.
03msc
RF is RF
The Natural State
Mag mounts should be temporary solutions. As said, drill the hole or change to a different type mount if this is a more permanent/regular installation.
