KJ4FWA
I am experiencing a rather unique situation with my antenna... Since fay is here my antenna mast was bent into a perfect 90 degree angle (well almost) and when that happened I lost all Com traffic (I also use my scanner as a radio so I dont have to use an alarm clock) Well Since I lost connection I disconnected the scanner from the antenna connector.. and it's hovering about an inch from the back of the unit... but I'm getting my signals with some static... when I connect the connector I have nothing... Do you think there's a problem with my antenna or with the cableing?
