Watertown (Site 41) Problems
jacobsonnr
Watertown, SD
I having problems monitoring the control channel 158.01 and getting nothing even when I do a Talk Group Search. But when I run the scanner with the talk channels like in a conventional channel I get alot of transmissions.
I have also since noticing the talk channels do have data I programmed the talk channels into a analog scanner and when that scanner stops on a channel nothing is displayed on the scanner when monitoring the control channel. Also, other sites around here work just fine like Summit and Webster.
I have veryified that the trunk data is exactly the same for both.
Thanks for your help. Im using a Uniden BC796D.
jacobsonnr
Watertown, SD
Additional Info
below is the log file from UniTrunker on that tower from an simple analog scanner (truncated for length):
Log file originally created as UniTrunker-20060914.LOG
50DF G 237 unknown single OSW *** with errors
D7DC G 0F3 unknown single OSW *** with errors
A7DC G 072 unknown single OSW *** with errors
C720 G 026 unknown single OSW *** with errors
DFDC G 0F2 unknown single OSW *** with errors
CB29 I 29A unknown single OSW *** with errors
D729 I 29A unknown single OSW *** with errors
37A2 G 2B4 unknown single OSW *** with errors
85AC G 22B unknown single OSW *** with errors
8533 G 23E unknown single OSW *** with errors
7001 G 3BE unknown single OSW *** with errors
B73C G 30D unknown single OSW *** with errors
4300 I 3BE unknown single OSW *** with errors
A23F G 172 unknown single OSW *** with errors
B5EE I 20D unknown single OSW *** with errors
4300 I 3BD unknown single OSW *** with errors
880E G 00E unknown single OSW *** with errors
5098 I 141 unknown single OSW *** with errors
6236 G 30B unknown single OSW ***
5398 G 321 unknown single OSW *** with errors
2400 G 3C1 unknown single OSW *** with errors
4900 G 3C2 unknown single OSW *** with errors
D600 G 3C2 unknown single OSW *** with errors
4900 G 3C0 unknown single OSW *** with errors
2006-09-14 05:15:19 2 of 43 (5%)
C273 I 2C9 unknown single OSW *** with errors
B63C G 38D unknown single OSW *** with errors
93E1 G 349 unknown single OSW *** with errors
B6DC G 383 unknown single OSW *** with errors
4300 I 3B9 unknown single OSW *** with errors
7FFF G 388 unknown single OSW *** with errors
4D90 I 3B9 unknown single OSW *** with errors
7FFF G 3B7 unknown single OSW *** with errors
2662 I 2D1 unknown single OSW *** with errors
4900 G 3C3 unknown single OSW *** with errors
53D2 G 03F unknown single OSW *** with errors
AE22 I 2DE unknown single OSW *** with errors
56E7 I 0C9 unknown single OSW *** with errors
51D0 I 21E unknown single OSW *** with errors
4900 G 3C1 unknown single OSW *** with errors
6C01 G 3BE unknown single OSW *** with errors
7001 G 3BD unknown single OSW *** with errors
2800 G 3C1 unknown single OSW *** with errors
3600 G 3C1 unknown single OSW *** with errors
B20C G 3B3 unknown single OSW *** with errors
2006-09-14 05:15:19 0 of 43 (0%)
6C01 G 3B9 unknown single OSW *** with errors
853C G 23F unknown single OSW *** with errors
7001 G 3B9 unknown single OSW *** with errors
A629 I 393 unknown single OSW *** with errors
437A G 0BE unknown single OSW *** with errors
A399 I 121 unknown single OSW *** with errors
6216 I 30B unknown single OSW ***
9399 G 2B8 unknown single OSW *** with errors
B796 G 1B3 unknown single OSW *** with errors
2725 G 358 unknown single OSW *** with errors
1F98 I 13F unknown single OSW *** with errors
BC97 I 37D unknown single OSW *** with errors
0B60 I 335 unknown single OSW *** with errors
E92A G 2A2 unknown single OSW *** with errors
7A67 G 337 unknown single OSW *** with errors
1F99 G 320 unknown single OSW *** with errors
8B60 I 314 unknown single OSW *** with errors
7C67 G 30B unknown single OSW *** with errors
8A2F G 20D unknown single OSW *** with errors
2D94 G 092 unknown single OSW *** with errors
88AF G 20D unknown single OSW *** with errors
E663 G 2DE unknown single OSW *** with errors
BEBF I 052 unknown single OSW *** with errors
A229 I 38F unknown single OSW *** with errors
2DAB I 111 unknown single OSW *** with errors
A629 I 38F unknown single OSW *** with errors
9F99 G 340 unknown single OSW *** with errors
6240 G 30B unknown single OSW ***
9F99 G 320 unknown single OSW *** with errors
2006-09-14 05:15:20 4 of 44 (9%)
2600 G 3C1 unknown single OSW *** with errors
5FFB G 04A unknown single OSW *** with errors
4100 I 3BE unknown single OSW *** with errors
3600 G 3C2 unknown single OSW *** with errors
4900 G 2B1 unknown single OSW *** with errors
A5A9 I 257 unknown single OSW *** with errors
778E G 016 unknown single OSW *** with errors
A229 I 257 unknown single OSW *** with errors
880E G 016 unknown single OSW *** with errors
2579 I 120 unknown single OSW *** with errors
6214 G 30B unknown single OSW *** with errors
8A14 G 00D unknown single OSW *** with errors
E6B7 G 361 unknown single OSW *** with errors
7063 G 021 unknown single OSW *** with errors
2600 G 3C0 unknown single OSW *** with errors
3001 G 3B8 unknown single OSW *** with errors
C793 G 239 unknown single OSW *** with errors
3001 G 3BD unknown single OSW *** with errors
A1A9 I 393 unknown single OSW *** with errors
E726 I 188 unknown single OSW *** with errors
880E G 021 unknown single OSW *** with errors
BE39 G 22A unknown single OSW *** with errors
6798 I 140 unknown single OSW *** with errors
880A G 020 unknown single OSW *** with errors
BEC8 G 26A unknown single OSW *** with errors
6798 G 320 unknown single OSW *** with errors
726B I 30B unknown single OSW *** with errors
CA22 G 372 unknown single OSW *** with errors
4300 I 3BF unknown single OSW *** with errors
626B I 30B unknown single OSW *** with errors
CA02 G 37C unknown single OSW *** with errors
B660 G 25E unknown single OSW *** with errors
BEBF I 192 unknown single OSW *** with errors
A1A9 I 383 unknown single OSW *** with errors
5E21 I 2B8 unknown single OSW *** with errors
A629 I 383 unknown single OSW *** with errors
880E G 0A2 unknown single OSW *** with errors
3F98 I 141 unknown single OSW *** with errors
8402 G 176 unknown single OSW *** with errors
3F99 I 120 unknown single OSW *** with errors
2006-09-14 05:15:20 1 of 52 (2%)
61C0 G 30B unknown single OSW *** with errors
7610 G 27D unknown single OSW *** with errors
A5BF G 162 unknown single OSW *** with errors
5D8D I 112 unknown single OSW *** with errors
8AEF I 16D unknown single OSW *** with errors
A23F G 162 unknown single OSW *** with errors
6B26 I 0CE unknown single OSW *** with errors
4DD2 G 013 unknown single OSW *** with errors
6B16 I 132 unknown single OSW *** with errors
3600 G 3C0 unknown single OSW *** with errors
7001 G 3B8 unknown single OSW *** with errors
4900 G 2B3 unknown single OSW *** with errors
C5EC G 3DF unknown single OSW *** with errors
2006-09-14 05:15:21 0 of 43 (0%)
loumaag
Silent Key - Aug 2014
Katy, TX
Your log indicates that you are not hearing the CCh well enough to do anything. In the shortened report you submitted, the best decode rate available was 9% that means during that period you missed 91% of the signals. Since most OSW's are multi-word affairs, your scanner is not seeing enough to decode the trunking commands.
Now that is the problem, the question is why? Your location says you are in Watertown, so there may be something interfering with the signal on 158.0100, do you have a portable scanner capable of decoding the state system? If so, wander around with it and see, failing that, start shutting down all possible interfering items in the vicinity of your 796, things like computers, DSL modems, other electronics to see if you can isolate the problem.
jacobsonnr
Watertown, SD
Same data about 15 ft from the tower with the only thing running a laptop about 5 ft away and my car on battery only with a BC350C. Maybe it's a test site for an encrypted control channel, god forbid the state screw with us? I hear SDHP on the Webster Tower on WTN INT/SRC quite often. Only problems is that the Webster and Summit towers are too far away to use the BC350C to see the data from them on UniTrunker or maybe the control channel is too distorted when put in thru the sound card on Watertown.
I'll contact my inside source for information tomarrow.
tyytor
Wyoming
at this point no sites are ENC only the fed stuff is (Radios) no sites,
i have picked up that site several times and there seens to be nothing wrong with the site
if you pick up others ok my be it is the nat WX service some times that intermods radios
i would check,
as for long rage sites i get sites most of the time at a 40 mile range with an outside antenna at 20 Ft. mast with a junk RS antenna, i would check a intermod problems.LOL
Hi Jacob;
To clarify, does Unitrunker work for you on other sites / systems ?
Here are some things to try:
1. Run an oscilloscope program; check for a clipped or weak waveform. You can post a screen-shot of the waveform here.
2. Are you sure the CC frequency is exactly 158.01 Mhz? Try tuning up/down a few khz and see if decoding improves.
3. If the signal looks good, try recording the signal to a WAV file - myself and others might be able to figure out what's going on.
This might not be an control channel.
-rick
jacobsonnr
Watertown, SD
This has been a problem for 2 or so weeks.
i would check,
I get Webster (about 33 Miles) and sometimes Summit (about 35 miles) with an internal 3 ft anntena but it's extremely fuzzy when listening to the control channel.
Not to sure what intermod is ...
jacobsonnr
Watertown, SD
rfmobile said:
Hi Jacob;
The analog scanner I use can't get the control channel to use UniTrunker from the other sites.
Screen Shots attached from my recorder program .. no Oscilliscope programs I found looked like an Oscilliscope genterated waveform I've ever seen ... 2 to 4 seperate lines?
158.0000, 158.0500, 158.1500, 158.2000 nothing.
It's the only Control Like channel from 150.0000-170.0000 in the area. Also, 1 WAV file in the ZIP file attached of the Control Channel Sound.
  • WtnSite.zip
jacobsonnr
Watertown, SD
Got it Working
OK, Thanks for the help guys!
I have got the system working. I have yet to get a freq that is not 000.0000! I'm getting at best 57% decoding tho. Might just have to put a tap on one of my scanners to see if something's up or not.
Thanks,
Nick
jacobsonnr
Watertown, SD
Maybe Control Channel Only?!?
I reprogrammed the BC796D the same way that my new PRO96 was since it worked and now the BC796D is tracking just like it should.
Here's the way I programmed the channels, just in case you have problems on the Wtn Site.
1 157.8900 Channel 1
2 158.5200 Channel 2
3 158.0100 Channel 3 (PCC)
4 158.6700 Channel 4 (SCC)
PCC=Primary Control Channel
SCC=Secondary Control Channel
Tho I know the names doesn't Matter it seems that it needs all the freqs in order like a EDACS does.
Nick
