jacobsonnr
I having problems monitoring the control channel 158.01 and getting nothing even when I do a Talk Group Search. But when I run the scanner with the talk channels like in a conventional channel I get alot of transmissions.
I have also since noticing the talk channels do have data I programmed the talk channels into a analog scanner and when that scanner stops on a channel nothing is displayed on the scanner when monitoring the control channel. Also, other sites around here work just fine like Summit and Webster.
I have veryified that the trunk data is exactly the same for both.
Thanks for your help. Im using a Uniden BC796D.
