way to fix bc250d volume knob
GNOFire
Jefferson,LA
I was wondering if there was a way to fix the volume knob on the uniden bc250d. In my stupidity I accidentally broke the knob off of the unit. The squelch knob remains. The unit itself works normally, however it cannot be turned off to be charged. It only works if I plug it into the wall adapter. Should I send the unit into uniden to be repaired or is there another way to fix it myself. Thanks for any help.
bcradio
Victoria BC
Don't know if it'll help you much, but when I broke the volume/squelch knob off my 780, I ordered knob assembly from Uniden and had a local radio shop install it for me. It was the knobs, the rod it's attached to plus the part that plugs into the circuit board inside. Park was only under $10, labour was about 30 or so. Worked great.
FD_1226
I dont know where to get it fixed but it is poorly designed. I bent mine and got it fixed alittle.
the vol/sql control is a very easy fix if you have the right tools. i have done about 50 of these controls, and can do them in about 20 mins. uniden charges about $ 60 for this repair and can probably do it in less time.
bill simpson
N8DRC
Grass Lake
I had the same thing happen to my 296 bent the knob,sent it back to Uniden took 2 weeks charged $56 but the radio came back like brand new,no problems..
Scan-Denver
Lakewood, CO - USA
I had the same thing happen to my 296 bent the knob,sent it back to Uniden took 2 weeks charged $56 but the radio came back like brand new,no problems..[/quote]
Ditto for me, came back like new ! I would suggest getting some kind of nylon carrier for your radio during transport - I use a nylon pistol carrier - something that has ample padding for your scanner in case you drop or bump it.
KME507
Lake Dallas, TX.
I have a question off the topic of broken knobs, but does the newer scanners have the same knobs on them? I have a 250D and think it would a good idea if Uniden came out with a volume/squelch control knob that would lock. I usually take the radio everywhere and listen to a combination of trunked and conventional frequencies and am always managing to turn the knobs inadvertantly. Alot of times I am listening to something in the trunked mode and the scanner skips to the conventional frequencies I have programmed and get the hiss from the squelch which can be very annoying. :?:
the 250d and the 296 use the same control. as for locking, i dont think you will see that too soon.
bill simpson
