Way to "Reset" G5 Bluetooth?
stevez97
Myrtle Beach, South Carolina
I was experimenting with my G-Cord Bluetooth adapter and was successful in the G5 identifying the adapter and asking for a passcode. I entered the usual 000 but got the "failed" response. I reset the G5 and tried to re-connect but now I don't get the opportunity to try a new code, it just goes directly to a "failed" status.
Is there a way to "delete" the G-Cord out of the G5 so I could repair and try a different code (perhaps 111?) A reboot didn't do the trick. Darn...............I was close, but not close enough. <sigh>
Thanks in advance.
JD21960
ILL-annoyed
Reset BT
The code is four zeros 0 or at least it is on mine as I've never set a code for any of it. I saw Unication David say it was all zeros a while back IF that screen comes up. You shouldn't need to reset anything, just scroll to the BT setting and turn both on and wait for it to match with your device. YOU can delete what you have listed by pressing SET at the bottom of the BT screen if anything is there.
