The database online is correct. If you haven't update your scanner from the online database it may not be correct in your scanner.
Safe-T takes a lot of patience to get correctly setup to monitor what you want. depending on how you loaded your program, and geographic location at any given time, you may lock onto a tower in another county that no one you want to listen to is associated with.
As a start look in the database and see what towers you want to monitor (Wayne Co has TWO, even though local law enforcement should probably be on both most of the time...)
7829 005 (5) Dalton Wayne 851.08750a 852.90000c
7829 018 (12) Richmond Wayne 852.93750a 853.11250c
program those four frequencies into your scanner as a new p25 trunked multisite networked system.
put in a wildcard or a dedicated list of talkgroups you want to hear
put you scanner into stationary mode (scan all control channels always)
you should hear any traffic in Wayne Co on the Safe-T system (below and State police also)
DEC HEX Mode Alpha Tag Description Tag
5744 167 D 89 FIRE DISP County Fire Dispatch Fire Dispatch
36384 8e2 D 89 FGD 1 County Fireground 1 Fire-Tac
36400 8e3 D 89 FGD 2 County Fireground 2 Fire-Tac
5712 165 D 89 CO DISP County Law Enforcement Dispatch Law Dispatch
5840 16d D 89 TALK County Car-to-Car Law Talk
5760 168 D 89 OPS 1 County Operations 1 Multi-Tac
5776 169 D 89 OPS 2 County Operations 2 Multi-Tac
5792 16a D 89 OPS 3 County Operations 3 Multi-Tac
5808 16b D 89 OPS 4 County Operations 4 Multi-Tac
5824 16c D 89 OPS 5 County Operations 5 Multi-Tac
5728 166 D 89 CITY DISP Richmond Police Dispatch Law Dispatch
You really need to learn about trunked systems to understand the programming...
Try these links...
Simple trunked explanation (READ ALL OF PAGE ABOVE LINK ALSO)
Trunking Basics - The RadioReference Wiki
A Great writeup on trunking and HOW TO PROGRAM it into a scanner....
http://wiki.radioreference.com/images/c/c7/Trunking_description.pdf
Please read the above links, and then come back with further specific questions... We're here to help, but you have to take the journey to learn....
P.S. there are probably a number of old VHF/UHF analog channels still in use in Wayne Co. You should probably scan for those as well to hear all the traffic for the County; even with Safe-T covering Sheriff, Police and fire in Richmond.
