From Jack J:
"I have repaired a few of them, Warren. In fact, I used to own one until a few years ago when I gave it to my son (still worked but had a few bad memory locations). I'd have to look but I think I have the blueprints around here somewhere. Surprised me when I ordered a service manual and that's what I got. The 101 used a few proprietary IC's and I think the memory chip was one of them. But I don't remember the IF being offset by band."
Ah, looks like I have found a fellow tech and 101 fan. You reminded me of that proprietary static memory chip and the trouble I had with Electra over it, one of the ports blew and wonder of wonders they sent me a replacement with the very same blown port. It made me wonder what kind of idiots they had working for them, it came wrapped in foil and the pins jammed into a piece of Styrofoam! The least they could have done was wrap bus wire around each one individually in turn and so on down the line, the holes in the foil were large enough there was no contact with them. Now isn't it customary to chop off a bit of the anti-static stock tube and ship the IC in it???
Unfortunately the weakest point in the whole thing was the slide switch (channel/programming switches) assembly. To save a buck the whole thing was an open printed board that collected dirt and had to be cleaned frequently. To make matters worse eventually the plating wore off and the slides broke contact necessitating replacement of the entire sub assembly.
I must give credit to the one who designed the receiver board, it was the hottest I have ever seen. The Cushman told the tale, it had such sensitivity and a low noise figure it made a lot of commercial gear look sick. The specs in the manual were a bit deceptive, usually they give threshold sensitivity but as I measured them they corresponded to the 20dB down or full quieting level. If I remember right they were something like <.1uV @ 160MHz and <.25uV @ 450Mhz.
Quite right N_Jay, single conversion receivers in particular were prone to compound errors. The VHF Lo Band was pretty much dead on, Hi Band wandered a bit but when you got up into UHF it really became noticeable. Extreme accuracy is difficult to achieve in the best crystal controlled master reference oscillators so when you get into the PLL controlled VCO and its inherent errors little things are compounded enormously and become noticeable. Thanks for jogging my memory, I think we just rediscovered the reason for that IF shift I wrote about earlier.
Oh and BTW has anyone noticed Trax has disappeared? I'll bet he's left the thread to the techies and went off shopping for a new scanner like he said he would. Heh, that kind of leaves the I triple E guy beating a horse that died way back on the last page now huh? (;->)
