Anyone else receiving a continuous weak signal on NTIRN control channel 858.1375 Mhz. In the past this had been the main control channel for Layer 2 (FW Fire etc.)
Ben, any problems near Central and Airport Fwy? I lose Sirius radio signals there.I've noticed my Unication G4/5s going out of range occasionally recently. It's often around Chick-Fil-A (Hwy 26 in Hurst), as well as Bedford Rd & Brown Tr. as well as work. I thought the work one might be related to new stuff on the tower there, but maybe there's something else going on.
I turned my scanner on for the first time in awhile, not receiving, only a quick flash of a full scale signal bar ocassionaly.
i turned my scanner on after 2 NRH medics and a engine flew by with police behind them.
i know there was actvity but could here any traffic. still can not.
sounds like im not the only having problems.
I am receiving as of this morning.
Thank you for the reply.I am in Keller area and we are seemingly seeing what we suspect is 5G interference perhaps?
Have not confirmed, but since the 5G local mini towers started popping in the area we also have seen some interference on the 800 Mhz Public Safety band in general at times with occasional "drop outs" of the signals when using a base station antenna at ~20'.... However, with just a rubber duck 800 Mhz antenna its less noticeable...No idea if related but seems more frequent since early spring time frame.
Scanner is an Uniden SDS 200.
This apparent interference along with the Simulcast challenges makes for interesting challenges..
That has a lot to do with the expansion of Fort Worth into nw tarrant up to the wise county line and also haslet becoming part of Fort Worth dispatches like lake worth and Saginaw.Not exactly on topic, but it looks like another transmitter site is in the works for Fort Worth according to a city council agenda item.
New N/NW transmitter site
