Weather Alert in Two Way Radio
SilentMarker
MS
I did a search, but could not find a thread on this question.
If I put the local NOAA frequency in a VHF handheld, is there a way to set up the channel so that it will only open the squelch when the alert tone sounds?
CanesFan95
Was Homeboys-Scanna
Banned
FL
How would you know that would work without knowing what radio it was?
a417
Because he is literally telling the OP what the decoding parameters are based on what NOAA transmits.
It would be the end user's responsibility to make sure the radio he has IFO him can physically do it.
N5XPM
Texas
Most land mobile radios for the past 20 years or so can select call on 1050 Hz. If a radio can’t, it is pretty easy to find one that can for a very reasonable amount.
radiomankc
The VHF radio must have Quick-Call II signaling on 1050 Hz in both tone slots.
