SDS100/SDS200: Weather alerts
BillC
Ouachita Parish LA
I’ve read the uniden docs as well as marks easy read manuals and I’m still confused about the wx function. Does the scanner have to be in a weather mode for the alerts to go off? I have the correct fips code in as well as the same codes for the wx types I want to be alerted on. The wx alert function is enabled. Problem is it doesn’t pick up the alerts during regular scanning. I can hear the audio cut out every 5 seconds so I think it’s working. But t no alerts come out
What am I doing wrong?
Thanks guys
Bill
JD21960
ILL-annoyed
Hope you get it fixed or have a backup. It's supposed to be one of THOSE WX events on Wednesday for your state and the mid-south. Good luck
n1chu
Farmington, Connecticut
I don’t believe the scanner will alert on the wx tones unless you have it parked on the wx frequency. It’s only designed to mute the wx audio until they broadcast the tone. The same is true with FD pager alerts... the scanner must be parked on the FD frequency while waiting for the tone alert.
baker50021
Ankeny, Iowa
What radio do you have?
The basic steps are enter your FIPs county code and then set the WX Priority to ON.
BillC
Ouachita Parish LA
sds100
I have the fips set and the same codes. And I have the wx alert on. Only time it’s worked is when I had it set to catch the weekly test
Bill
JoeBearcat
Uniden Representative
Thanks guys
Bill
Which weather alert mode? (there are two and it seems like you are confusing them)
There is the WX Priority which uses the 1050 Hz tone to alert. You can use that while scanning but it does create gaps in the audio while it samples the WX channel for the alert tone.
Then there is the FIPS/SAME mode which does have to be a dedicated mode since the FIPS codes are sent much faster than the 1050 Hz alert tone and cannot be acquired via sample.
BillC
Ouachita Parish LA
So it’s all or nothing if you want to have alerts while scanning? Just delete the fips and same codes and turn the wx priority?
JoeBearcat
Yes. FIPS/SAME is sent too fast to sample while scanning.
CHHTX
Donna TX
Just to mention, and maybe I'm misunderstanding it but this is a little surprising to me. As I read this, it sounds like if you run WX priority then you'll have gaps in the audio when there are other, non-WX hits (like police/fire for example). And if you use the FIPS/SAME then you're locking your radio into only that and it will remain quiet until there's an alert for your fips/same area. It's just odd to me that you can't set the scanner to monitor the frequency without gaps in the audio of other hits. I'll bet there's a valid reason that there are gaps and likely Uniden would prefer not to have the gaps and just can't help it.
The good news is you can get a cheapie weather alert radio to do the job in your shack/home.
hiegtx
Dallas, TX
The scanner has only one receiver, so it's not possible to continuously monitor weather radio for FIPS codes while also scanning a wide variety of other systems.
The 'break' in audio, for the scanner to duck over to the weather frequency and look for the tone is very brief, a fraction of a second. You have the same brief interruption if you are using priority on conventional systems. In that case, the interruption hiccup is affected by how many active channels are set for priority scan. You can also set the time interval between priority checks from one to as much as ten seconds. For weather, the interval is set as five seconds.
A weather radio is your best option if you want to utilize the FIPS codes. I'f I'm away from home, I sometimes take along one of my older scanners that is no longer in active use. I can park it in the weather monitoring mode without affecting what I'm scanning with the other scanners.
